[GRASSLIST:1469] Problems starting GRASS-5
Rich Shepard
rshepard at appl-ecosys.com
Sat Feb 17 21:41:44 EST 2001
While 4.3 ran just fine for me, I cannot get 5.0-beta-11.2 off the ground.
Here is where everything is, perhaps someone will be kind enough to tell me
what I've overlooked.
/opt/grass5/grass5-beta-11.2/ has all the source code. After running
./configure, make, and make install, there's also /usr/local/grass5/.
For the project I want to develop now, I created the directory
/mnt/usr4/coeur-rochester/. Under this, I created two new directories,
PERMANENT/ and data/. Ownership of /mnt/usr4/coeur-rochester/ (and all
subdirectories below it) is root.users, so any user in the group ('users')
can work with these data.
When I try to start GRASS from within /mnt/usr4/coeur-rochester/, I see a
small, empty window. When I kill that, I read:
[rshepard at salmo coeur-rochester]$ grass5
Starting GRASS ...
/usr/local/grass5/etc/Init.sh: GISDBASE: parameter null or not set
I do not see where I set GISDBASE in the Init.sh script. I also have
initial data (in the form of MapInfo .mif/.mid files) that ought to
translate correctly into GRASS format. Where do I specify the coordinate
system, projection, datum, bounds of the coverage, etc? What do I specify
for location (/mnt/usr4/coeur-rochester/?), $GISDBASE and mapset?
My playing with 4.3 was with the spearfish data set, so these questions
never came up: I just followed the tutorials and became familiar with
different modules. Now, however, playtime is over and I need to transition
to 5.0 for production (i.e., paying) work.
Is there documentation I've missed that answers my questions? If so, just
pass me a pointer and I'll go read it for myself. Despite my
somewhat-limited experience, and my extensive reading, I'm totally stymied.
Jump starts solicited. :-)
Thanks,
Rich
Dr. Richard B. Shepard, President
Applied Ecosystem Services, Inc. (TM)
Making environmentally-responsible mining happen. (SM)
2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
