[GRASSLIST:1497] RE: r3.showdspf
Artemis fgu at mail.gorny.ru
Fri Feb 23 07:07:22 EST 2001
as far as I know, libXm is the motif/lesstif main library.
Install something like lesstif-dev in your distribution.
Hope this helps,
Artemis.
> Thanks for your answer!
> We have installed Mesa-widgets and solved the problem with the: libGLw.so.3.
> Now we are asked aboute a new library: libXm.so.1. What do this library
> belong to?
> And are there any other dependencies???
> Regards,
> Mona
> -----Original Message-----
> From: Venkatesh Raghavan [mailto:raghavan at media.osaka-cu.ac.jp]
> Sent: Thursday, February 22, 2001 1:50 AM
> To: Johansen Mona
> Subject: Re: [GRASSLIST:1460] r3.showdspf
> Hi Mona
> Regarding the g3d compilation I had to compile the
> mesa widgets to create the libMesaGLw.a libMesaGLwM.a
> libraries. Moved these libraries to /usr/lib and
> added them to the OGLLIB in the
> src.contrib/GMSL/g3d/src3d/raster/r3.showdspf.openGL/Gmakefile
> as shown below;
> OGLLIB=-lGL -lGLw -lMesaGLw -lMesaGLwM ${LGLWM} -lXm -lX11 -lXt -lXext
> Subsequently the g3d including r3.showdspf.openGL could also be
> compiled without a hitch.
> Mesa widgets source code is available with the Mesa code and
> will generate the required libraries when compiled.
> Hope this helps.
> Raghavan
> Johansen Mona wrote:
> > Hello,
> > I use the r3.showdspf to display isosurfaces previously calculated
> > with r3.mkdspf. I get the error message "error in loading shared
> libraries:
> > libGLw.so.3".
> > After installing Mesa, the same error occures.
> > Mona
