[GRASSLIST:1379] Re: importing ESRI-ARC/INFO BIL into GRASS
Andreas Lange Andreas.Lange at Rhein-Main.de
Sun Jan 21 12:01:01 EST 2001
Hi Markus, hi others,
thanks a lot for the hint.
The information in the stx file is not needed (statistics on the BIL
file).
But am i correct that without a "prj" file i have no chance to get the
projection of the BIL file?
It is for sure not lat/lon as i can see from the values of the
header/world file.
I'll explore if the import can be done with a script (r.in.bil).
Thanks,
Andreas
Markus Neteler wrote:
> Andreas,
> check this page:
> http://edcnts12.cr.usgs.gov/ned/appendix2.htm
> Bil format documentation
> stx and friends are mentioned. Perhaps r.in.bin can be extended.
> Hope this helps,
>  Markus Neteler
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
