[GRASSLIST:1380] Re: importing ESRI-ARC/INFO BIL into GRASS
Markus Neteler
neteler at geog.uni-hannover.de
Sun Jan 21 12:43:52 EST 2001
Hi Andreas,
[bounced mail to list]
On Sun, Jan 21, 2001 at 06:01:01PM +0100, Andreas Lange wrote:
> Hi Markus, hi others,
> thanks a lot for the hint.
> The information in the stx file is not needed (statistics on the BIL
> file).
> But am i correct that without a "prj" file i have no chance to get the
> projection of the BIL file?
I guess that's impossible as the BIL is a simple format.
> It is for sure not lat/lon as i can see from the values of the
> header/world file.
> I'll explore if the import can be done with a script (r.in.bil).
Perhaps a "-t" flag should be added to r.in.bin like in r.in.tiff.
Or you write r.in.bil using the .tfw file and r.in.bin parameters.
To decipher you can extract the old r.in.arctiff script from beta9
if you don't want to modify r.in.bil directly.
Just a hint,
Markus
