[GRASSLIST:2047] Re: Nviz
Glynn Clements glynn.clements at virgin.net
Mon Jul 2 06:28:56 EDT 2001
michele.rocc at libero.it wrote:
> I tried to run the Nviz interface with grass5pre1 in a linux redat7.1;
> the tcltkgrass interface work fine, but Nviz gives a problem (can't
> load libtk8.3). If tcltkgrass works with the same libraries do anyone
> have an idea to solve this problem?
tcltkgrass consists of Tcl/Tk scripts which are executed using the
standard "wish" shell. nviz uses a customised "wish" shell which
includes an OpenGL widget.
Where is libtk8.3.so installed? If it's in /usr/local/lib, you will
need to add /usr/local/lib to /etc/ld.so.conf then re-run ldconfig.
Glynn Clements <glynn.clements at virgin.net>
