[GRASSLIST:2103] Re: Vector Import..
Hans Koren
Hans.Koren at nr.no
Fri Jul 13 10:40:55 EDT 2001
I am running GRASS 5.0.0pre1 (May 2001) on Solaris 2.7
Hans
Markus Neteler wrote:
> Hi,
> please post to the list, which GRASS 5 version you are using.
> The latest?
> On Fri, Jul 13, 2001 at 04:00:57PM +0200, Hans Koren wrote:
> > I just tried to send a message to grasslist, but half of the message
> > disappeared. Here I try again.
> > I have just started to try to use Grass, and have som problems with
> > import of vector images. I have succeeded in importing a vector image by
> > using m.in.e00, and have even managed to transform the vector map to
> > raster by v.to.rast.
> > But when I try to import the same vector data as a shape file (with
> > default options) I get the following messages:
> > Processing shape 1 of 159
> > Processing shape 159 of 159
> > Number of shapes registered is 0
> > Number of parts registered is 167
> > Number of valid records is 391848 of 0
> > Extracting and storing area edges...
> > Tracking line 1.
> > Tracking line 2.
> > Tracking line 3.
> > Tracking line 4.
> > When I use the command line I even get a message of Segmentation fault.
> > In the directories dig and dig_att I get a file with the correct name
> > and size 0.
> > Can anyone tell me what might be wrong?
> > Thanks.
> > Hans Koren
