[GRASSLIST:2135] Re: r.reclass: how to reclass only part of the categories
Markus Neteler neteler at geog.uni-hannover.de
Fri Jul 20 08:01:10 EDT 2001
On Fri, Jul 20, 2001 at 12:19:04PM +0200, mlennert at club.worldonline.be wrote:
> Hello,
> I've downloaded some GLOBE DEM files, and I would like to use them in nviz.
> The problem is that some areas (such as the polders in Holland) have values
> around 65500, making it difficult to use the files in nviz due to the extreme
> differences in values. I would therefore like to reclass them in order to give
> them all a value of -1.
> Now r.reclass allows me to either use reclass rules, but then I would have to
> write a reclass rule for evey point between 0 and 9000 (the ones I want to
> keep the way they are) since if I don't do it, r.reclass will class them all
> as NULL. And if I use the r.reclass interface, I would have to do all the
> changes to -1 by hand.
> So my question: is there a reclass rule meaning something like 'leave 1 thru
> 9000 the way they are' ?
> Or: is there a way to tell nviz to not take into accont z values outside of a
> defined range ?
 Moritz,
the value "65500" look as if the data are not correctly imported (see other
comment from Roger). Did you use
 r.in.globedem
This module may fail as the GLOBE data eventually have a different
encoding since some weeks (not sure). If so, it would be great to
have r.in.globedem updated.
Maybe this is a hint,
 Markus
