[GRASSLIST:2176] Projection questions
    Rich Shepard
    rshepard at appl-ecosys.com
    Fri Jul 27 12:32:52 EDT 2001
  I have a bunch of questions about the storage of information about mapset
projections/coordinate systems/datum in GRASS-5. Let me start with a few.
  1.) When I used r.in.gdal to import a DEM, the PROJ_UNITS file contains
this:
unit: unknown
units: unknowns
meter: 1
  Can someone please interpret this for me? I assume that it means the units
are meters, but why this syntax?
  2.) Considering the same data set, the DEFAULT_WIND file contains:
proj:       1
zone:       11
north:      4469934
south:      4455924
east:       404501.28124
west:       393671.28124
cols:       361
rows:       467
e-w resol:  30
n-s resol:  30
  I assume that "proj: 1" indicates UTM (because the PROJ_INFO file says
so. But, where is the file that associates the number with the projection
name? I've looked all through /usr/local/grass5/etc and the other
directories there, but can't find it.
Thanks,
Rich
Dr. Richard B. Shepard, President
                       Applied Ecosystem Services, Inc. (TM)
            2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
 + 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
                 Making environmentally-responsible mining happen.
