[GRASSLIST:2192] Another problem with r.proj
Rich Shepard rshepard at appl-ecosys.com
Fri Jul 27 21:36:36 EDT 2001
  After a lot of reading and experimenting, I _thought_ that I had a handle
on how to get r.proj to work. Wrong! Here's the scenario:
  I start grass5 from the destination location/mapset: temp-UTM/PERMANENT/.
This mapset has the location's default window, window, projection
informatino and projection units. All UTM, Zone 11, meters.
  I then ask to reproject a map from location/mapset: nevada/spc/. But, I
get an error:
GRASS:/mnt/usr4/projects/temp-UTM/PERMANENT > r.proj input=plss-r location=nevada
cannot initialize pj
cause: projection not named
ERROR: Can't get projection key values of output map
  This makes no sense to me. In the destination location/mapset _are_ the
projection name (in PERMANENT/PROJ_INFO). It must be something silly I've
missed, but I just cannot see it.
Any ideas? Thanks,
Rich
Dr. Richard B. Shepard, President
                       Applied Ecosystem Services, Inc. (TM)
            2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
 + 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
                 Making environmentally-responsible mining happen.
