[GRASSLIST:2193] Re: Another problem with r.proj
Eric G. Miller
egm2 at jps.net
Fri Jul 27 23:09:52 EDT 2001
On Fri, Jul 27, 2001 at 06:36:36PM -0700, Rich Shepard wrote:
> After a lot of reading and experimenting, I _thought_ that I had a handle
> on how to get r.proj to work. Wrong! Here's the scenario:
> I start grass5 from the destination location/mapset: temp-UTM/PERMANENT/.
> This mapset has the location's default window, window, projection
> informatino and projection units. All UTM, Zone 11, meters.
> I then ask to reproject a map from location/mapset: nevada/spc/. But, I
> get an error:
> GRASS:/mnt/usr4/projects/temp-UTM/PERMANENT > r.proj input=plss-r location=nevada
> cannot initialize pj
> cause: projection not named
> ERROR: Can't get projection key values of output map
> This makes no sense to me. In the destination location/mapset _are_ the
> projection name (in PERMANENT/PROJ_INFO). It must be something silly I've
> missed, but I just cannot see it.
> Any ideas? Thanks,
Please report for both source and destination locations: WIND, PROJ_INFO,
PROJ_UNITS. Also, the cellhd/<source> file (has the WIND info for the
input raster).
Eric G. Miller <egm2 at jps.net>
