[GRASSLIST:2197] Re: Another problem with r.proj
Rich Shepard rshepard at appl-ecosys.com
Sat Jul 28 12:57:43 EDT 2001
On Sun, 29 Jul 2001, Len Coop wrote:
> Here is the start of the manpage. If you didnt see those options you must
> have a funny page: (location= does not include the mapset too) - Len
>              mapset   mapset of input map
>               dbase   path to GRASS database of input location
Len,
  Makes no difference:
GRASS:/mnt/usr4/projects/temp-UTM/PERMANENT > r.proj input=plss-r location=nevada mapset=spc
cannot initialize pj
cause: projection not named
ERROR: Can't get projection key values of output map
GRASS:/mnt/usr4/projects/temp-UTM/PERMANENT > r.proj input=plss-r location=nevada mapset=spc dbase=/mnt/usr4/project
  Explicitly adding the input mapset name and the dbase (which I assume is
$GISDBASE), still results in the module's inability to get the key values
(whichever those are) for the _output_ map.
Thanks for the suggestion,
Rich
Dr. Richard B. Shepard, President
                       Applied Ecosystem Services, Inc. (TM)
            2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
 + 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
                 Making environmentally-responsible mining happen.
