[GRASSLIST:2212] Re: Another problem with r.proj
Eric G. Miller
egm2 at jps.net
Sun Jul 29 16:41:46 EDT 2001
On Sun, Jul 29, 2001 at 11:40:43AM -0700, Rich Shepard wrote:
> I suspect that I know why r.proj failed for me but worked for Eric. If I'm
> right, we have a major deficiency in GRASS -- IMO, of course. :-)
> The files I was trying to reproject are vector files: public land survey
> system (PLSS) and mining claims. Once I get everything set up properly and
> working, I'll be converting these to rasters for analytical purposes, but I
> also need the vectors for printed output purposes. I never made the
> connection before between the "r." and the vector files.
Fifty lashes with a wet noodle for you!
> Is this the problem? Is running affine transformations on the arc-nodes of
> a vector map so much different from running them on a grid?
Why would you use an affine transformation for vectors? v.proj will do
an inverse followed by a foward projection for each vertex (depending on
input/output projections -- e.g. only the inverse or forward is done if
the target or source is lat/lon). See v.plant for adding extra vertices
at a specified interval (will reduce apparent error in line work that is
projected if the original map has widely spaced vertices).
Eric G. Miller <egm2 at jps.net>
