[GRASSLIST:1943] Re: Web Aplication - Grass / Mapserver
Howard Tan
Howard.L.Tan at jpl.nasa.gov
Mon Jun 11 15:31:00 EDT 2001
I've developed Internet map application using Visual Basic, MapObject, and
MapObjects IMS. It requires programming, but it has easy to follow
tutorials. You don't get the wizard like ease of use like ArcIMS, but my
applications have been running solid for the past year under NT4.0.
MapObjects is also a ESRI product, which means some serious dough.
Howard
----- Original Message -----
To: "Lars Bromley" <lbromley at aaas.org>
Cc: <grasslist at baylor.edu>; <miki at canaan.co.il>
Sent: Monday, June 11, 2001 7:15 AM
Subject: [GRASSLIST:1936] Re: Web Aplication - Grass / Mapserver
> Lars Bromley wrote:
> >There is of course ArcIMS from ESRI, a commercial product, which is
supposedly fairly robust.
> As long as you don't use the NT server version. Our IMS server has
> such a horrible memory leak that it needs to be restarted about once
> per day. I've not tried the Solaris or Linux versions yet, but may be
> migrating to that this summer if ESRI doesn't fix the problem with the
> new release.
> Bruce
