[GRASSLIST:1996] Re: Aspect and Shaded relief
Markus Neteler neteler at geog.uni-hannover.de
Wed Jun 20 13:20:33 EDT 2001
On Wed, Jun 20, 2001 at 08:57:20AM -0400, Patrick Dunlavey wrote:
> At 01:28 PM 6/20/01 +0200, Karin(e) ZUERCHER wrote:
> >Hello everybody!
> >With Arcview and some others, it is possible to make a nice picture of the
> >relief called 'sheade relief' or something, where you can choose the
> >orientation and hight of the light source (sun). There is also something
> >called aspect map, but it only gives a result of slope orientation without
> >accounting for inclination (thus you get a look of V shaped valleys instaed
> >of U shaped, fo rinstance).
> >I know about and until now used grass ASPECT map to get more or less a
> >shaded relief.  I didn't find any module that seams to allow making shaded
> >reliefs like in arcview or so.
> >I am wondering, did I miss something or deos it not exist in grass yet?
> >I that's the case, I guess it should be possible to compute something with
> >slope and aspect map, and wonder if someone has an idea how that is done
> >(what algorithms or whatever needed)?
> >Thanx in advance for your help
> >In Kindness
> >Karine
> There is a script called shade.rel.sh in your grass5/scripts directory,
> which uses r.mapcalc. It works pretty well, at least when your x, y and z
> coordinates are all in the same units. There's also shade.color.sh, which I
> haven't played with.
> -- Pat
you may also use d.his and "overlay" the map (DEM or whatever) to
the aspect map. See the related tcltkgrass entry "shaded relief" as
well.
Hope this helps,
 Markus
