[GRASSLIST:1995] Re: v.digit and other problem
Markus Neteler neteler at geog.uni-hannover.de
Wed Jun 20 13:26:21 EDT 2001
On Wed, Jun 20, 2001 at 03:41:32PM +0200, georges..schwob wrote:
> Dear friends,
> I work with Grass4.3 and a Mandrake Linux plateform.
> When I launch v.digit I receive the following message: "Can't open file
> for read :/usr/local/grass43/etc/digcap
> Contact your Grass system administrator"
> There is only "digcap.sampl" file in this directory.
usually the install script copies digcap.sampl to digcap. So just
cp digcap.sampl digcap
Then it should work.
> So I try to get some help into the downloaded Grass 4.0 map digitizing
> manual (Postscript 53 pages), unfortunately, the gunzip command refuse to
> work and says that the file is not a gzip format ???
Please check again:
http://www.geog.uni-hannover.de/grass/gdp/index.html
I have converted the digit.ps.gz to digit.pdf. Now you should be able
to download.
Hope this helps,
 Markus Neteler
