[GRASSLIST:1588] Re: interpolate nominal values
SUSANNE HOFGAERTNER
hofgaertner at fh-nuertingen.de
Fri Mar 9 06:23:52 EST 2001
On 8 Mar 01, Rich Shepard wrote:
> On Thu, 8 Mar 2001, SUSANNE HOFGAERTNER wrote:
> > I want to interpolate nominal data (soil types as point information).
> > Which possibilities do I have, what's the best method? -Any experiences,
> > suggestions?
> Susanne,
> While modules such as s.surf.idw will interpolate points to form a
> surface, it will have no meaning with nominal values. (I presume you mean
> nominal in the data type sense of having numbers assigned to categories,
> without any mathematical relationships among the numbers.)
> What are you trying to do?
> Rich
Rich,
your definition of nominal is exactly what I mean.
Here's a more detailed description of what I want to do:
I've got point data with information on moisture, nutrients and soil
type and I've got grid data with information on slope and on classes
of warmth.
What I want to get in the end is a surface showing categories of a
combination of the above features. This means I'll have areas with a
code like for example: 01331 (which means 0:slope=0-10%,
1:warmth=cold, 3:moisture=dry, 3:nutrients=little, 1:soil type=clay).
This is a methodology used to determine the eligibility for different
land uses (finding out about eligibility would be the next step to do).
Now there are two different approaches:
1. first produce grids from my point data for the single features
(moisture, nutrients and soil type) , afterwards combine them to get
my end surface with combinded categories
or
2. assign my grid information (warmth and slope) to my points,
create a new point attribute "category" with all my single features
combined, then create my surface out of this new attribute.
In both cases I have to "interpolate" nominal data (case 1: soil type,
case 2: combined categories).
What I already tried out is r.neighbors with the "mode" method.
Therefore I first converted my point data to raster data with no-data-
values between my points. I think this is something I could work with
but I just wondered if there's a better method out there.
I also tried the Thiessen-Polygons but the resulting areas don't look
"right" (it looks like a patchwork).
Here are some comments to the other answers to my request:
On 8 Mar 01, sturm at datacomm.ch wrote:
> Hi Susanne
> I made very good experiences with s.surf.rst (regularised splines
with tension).
> I used it for the interpoaltion of rainfall point data. I wrote a small
perl
> script with which you can determine the best available
interpolation model (comparing
> IDW and RST) by using the cross validation method. You will have
to 'play' with
> the RST parameters in order to get quite accurate results. In the
best cases
> I achieved a correlation coefficient of 0.9 for the RST model. But
the cross
> validation approach took over a week processor time to compute
the best fit...
> If you'd like I can post you the perl script (but you'll have to adapt it
to
> your own needs)
> Bernhard Sturm
Bernhard,
thank you for offering your script but I don't think that interpolation
methods like IDW, RST or Spline can help me with my problem
since I'm handling with nominal data. (Also: since I'm new to
GRASS, and Linux I have no idea how to work with a perl script... I
guess that's something I better won't deal with now).
On 8 Mar 01, Edzer J. Pebesma wrote:
> They're hard to interpolate. Nearest neighbour (forming thiessen
polygon) seems
> a useful action; indicator simulation another one. Most
interpolation methods
> are based on weighted averages, and are therefore only suitable
> to interval/ratio data. Don't use them.
> Edzer
Edzer,
what do you mean with "indicator simulation"?
Susanne Hofgaertner
Fachhochschule Nuertingen
Institut fuer Angewandte Forschung
Schelmenwasen 6-8
72622 Nuertingen
