[GRASSLIST:1639] Re: display several maps
Gail Higginbottom
ghigginb at physics.adelaide.edu.au
Mon Mar 19 23:50:48 EST 2001
r.patch is used to to make a composite map layer from several map layers
which are "registered to the same area of the Earth's surface". So I dont
think it will help Julien. I think JUlien is looking for something that
creates one large map from several "sub-maps" of an entire region .
best wishes,
Gail
Gail Higginbottom,
Centre for European Studies and General Linguistics,
University of Adelaide,
Adelaide, South Australia,
Australia. 5005.
and
Department of Physics and Mathematical Physics
http://www.physics.adelaide.edu.au/~ghigginb/
(08) 8303:6440
On Tue, 20 Mar 2001, Justin Hickey wrote:
> Hi Julien
> julien wrote:
> > Hi list,
> > I'm working on a project into GRASS which is composed by several
> > maps. (raster).
> > These maps have been imported into GRASS using r.in.tiff. and
> > r.support.
> > Each of these maps has the good coordinates. They compose a large
> > map.
> > But how can I display these maps together in the monitor ?
> > Using d.rast -o map1 ... d.rast -o map2 ...is quiet boring when you
> > have 10 or more maps !
> > I've thought to write a small script to do that but maybe there is a
> > module to create a group of maps in a project.
> > I've tried to create a new group composed by all these maps but I'm
> > not able to display it (the name of these groups does not appear in
> > the g.list rast).
> I'm not sure what you did to try and group your maps. However, I believe
> the command to use to create a single raster map out of several smaller
> maps is r.patch. Please see the html documentation that comes with Grass
> (starting point is documents/index.html). Select the raster commands
> link and then the r.patch link. Please note that there are tips in the
> "Notes" section that may be useful to you.
> Hope this helps.
> Sincerely,
> Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
> High Performance Computing Center
> National Electronics and Computer Technology Center (NECTEC)
> Bangkok, Thailand
> People who think they know everything are very irritating to those
> of us who do. ---Anonymous
> Jazz and Trek Rule!!!
