[GRASSLIST:1685] Re: GRASS Cygwin Binary Installation problems.
Malcolm Blue mblue at nb.sympatico.ca
Thu Mar 29 17:46:54 EST 2001
Howard,
As Glynn said, the programs in /usr/local/grass5/etc/bin/cmd/ are the
actual programs.  Since these files are all missing, there is something
wrong with the installation or the distribution that you received.  I
recommend waiting for the new version.  This should be very soon.
I don't have the binary distribution, so I can't look to see what is in
it.  If you don't mind waiting, I think it will go easier for you, since
these are the kinds of problems Andreas is working to overcome.
Sorry for the inconvenience.
Malcolm
[Please excuse the double posting if you are subscribed to the new
winGRASS list as well as GRASSLIST.  Since this discussion has been on
the GRASSLIST, I am cc'ing there.  This belongs on the NEW winGRASS list
now so I am sending it to there.]
Glynn Clements wrote:
> Howard Tan wrote:
>> I looked in '/usr/local/grass5/etc/bin/cmd/'. The directory was completely
>> empty.
> The installation is completely screwed, then. All of the actual
> programs live in there (371 files, for me). The stuff in grass5/bin
> (on a Unix sytem these are just hard links to grass5/etc/front.end),
> just invokes the corresponding program in grass5/etc/bin/cmd or
> grass5/etc/bin/inter as appropriate.
>> I found I had a copy of g.gisenv in 'd:\cygwin\usr\local\grass5\bin'.
>> I copied the file to '/usr/local/grass5/etc/bin/cmd/'. I tried to start
>> grass, and I got past the first screen, and where it normally coughs out, it
>> clear the screen and start to do something on the harddrive. I waited for
>> about 5 minutes and it didn't finish. I got impatient and closed the window.
>> I then proceeded to run through the steps you illustrated... After it runs
>> for about 30 minutes I got the following error:
>> 'd:\cygwin\usr\local\grass5\etc\bin\cmd\g.gisenv: *** couldn't commit memory
>> for cygwin heap, Win32 error 487'
> Yep. grass5/bin/g.gisenv just invokes grass5/etc/bin/cmd/g.gisenv,
> which should be the actual program, but in your case it's just a copy
> of grass5/bin/g.gisenv, resulting in infinite regression.
