[GRASSLIST:1811] Re: r.in.bin
    Glynn Clements
    glynn.clements at virgin.net
    Fri May  4 19:26:55 EDT 2001
kevin cross wrote:
>     I have posed this question before but not with this detail.
> I get a moat around the central valley of California, and
> since I live here I know it doesn't exist!.  Basically it is the
> same problem you are having, though I think I recalled
> negative values all the way to about -450.
If so, then it isn't the problem Yan was having. That was caused by
using the "-s" flag, which should only be used on 1-byte-per-cell
data.
Glynn Clements <glynn.clements at virgin.net>
