[GRASSLIST:1821] Re: r.in.bin
Glynn Clements
glynn.clements at virgin.net
Tue May 8 07:04:16 EDT 2001
Yan Fitterer wrote:
> I'm baffled at this, as I remember trying it without -s, and not getting
> negative values (which you do need now and again - not counting the fact that
> on the gtopo30, the sea is at -9999).
I don't have any problems importing GTOPO30 data with the latest
version of r.in.bin (note that you can also use r.in.gdal if you have
the GDAL library). And I do get negative values (e.g. large parts of
The Netherlands); using "anull=-9999" takes care of the NULL values.
Glynn Clements <glynn.clements at virgin.net>
