[GRASSLIST:1822] Re: Thinned line lenght
Markus Neteler
neteler at geog.uni-hannover.de
Tue May 8 08:01:33 EDT 2001
On Mon, May 07, 2001 at 05:20:00PM +0200, Aldo Clerici wrote:
> Hi to everybody.
> Is there in grass a command or script to compute the lenght of thinned
> raster lines considering the different lenght of the diagonal cells?
> Many thanks in advance
> Aldo Clerici
A possible way might be to use
r.line
on that raster lines. As r.line (currently) doesn't have a smooth function,
it might be a good idea to use v,support, v.digit afterwards. In v.digit you
find in EDIT-> v - Smooth poly-line a way to "smooth" the line.
Maybe also v.prune would do the job.
Finally v.report tells you the line lenght.
Hope this helps,
Markus
PS: It might be a good idea to have a new flag in r.line to create diagonal
lines optionally instead of digitizing the cell borders.
