[GRASSLIST:1843] RE: GRASS 5 display questions
Dieter Lehmann lehmann at fh-nuertingen.de
Tue May 15 08:58:06 EDT 2001
only an idea...
I'm working a lot with ArcView, there are sometimes strange problems when the
nodes are not snapped, seems, you should check that (eventually in MapInfo).
Even duplicated lines result in pretty obscure behavior.
Try v.digit on your data, that might help.
I don't think, thats only a display problem.
Hope it helps.
Dieter
On 14-May-01 Rich Shepard wrote:
>   I have a vector layer that is imperfectly imported from MapInfo
> (v.in.mif). When I try to interactively zoom in (d.zoom), I get an error box
> at the bottom telling me that the north value must be greater than the south
> value. (Sarcastic comment not provided; the computer wouldn't understand it
> anyway.) But, if I select a larger area, it works.
>   Also, if I select a medium-size area, I don't see what I outlined, but an
> open multiple-line figure. I've no idea from where this comes.
>   Any ideas what might be going on here?
> Rich
> Dr. Richard B. Shepard, President
>                        Applied Ecosystem Services, Inc. (TM)
>             2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
>  + 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
Dieter Lehmann
University of applied Sciences
Schelmenwasen 4-8
D-72622 Nuertingen, Germany
Phone: +49 (0) 7022 404 Ext. 207
Fax: +49 (0) 7022 404 Ext. 209
Date: Mon, 15-May-01 12:00:00 +0000 (GMT)
Time: 14:51:24
