[GRASSLIST:1859] Re: Can't open the monitor with grass5.0.0pre
Glynn Clements glynn.clements at virgin.net
Tue May 22 12:41:17 EDT 2001
Seppo Kaitala wrote:
> I am running RH 7.1 and just compiled new grass5.0.0pre1.
> I have problem vith the monitors, Actually the monitor opens, but i
> cannot draw anything on that.
Is the region set correctly? Can you provide an example session?
> During the compillation I got the response
> checking GL/gl.h and GL/GLwMDrawA.h... configure: warning: *** Did not
> find GL/GLwMDrawA.h
This has nothing to do with the monitor; GL/GLwMDrawA.h should only be
required for grid3d (GMSL/g3d), which isn't part of the release.
> Should I edit the header file to find that GL or is that missing in
> RH7.1 or in my computer.
No; you can ignore the warning.
Glynn Clements <glynn.clements at virgin.net>
