[GRASSLIST:2626] Can I import these?
Ben Logan blogan at newcreature.org
Thu Nov 1 07:33:36 EST 2001
Hello,
Some time ago, I ordered a free CD offered by the Virginia Department
of Transportation.  It basically contains the data (or part of it)
that the VDOT uses to generate the county maps.  The CD says "Network
Level Basemap" and "ARC/INFO(R) Coverages" on it.
It came with software (for Windoze, of course) by ESRI called
ArcExplorer, which allows you to view the maps, and put various pieces
of them together.  I sure would like to be able to import them into
GRASS, but I'm not sure exactly what format they are in.
I've included a dump of the directory structure of the CD (created
with 'tree').  I edited the dump to make it shorter, since is was over
600Kb, and added a few comments marked with a hash (#).
The html docs on the CD weren't very helpful to me, but might be to
someone who knows what they're doing. :)  If you can't tell what
format the files are in by their extensions, I can send you the
relevant html file(s).
Thanks,
Ben
Ben Logan: blogan at newcreature dot org
OpenPGP Key KeyID: A1ADD1F0
. # The CD root
|-- _private
|-- arcexplorer
|   `-- aeclient.exe
|-- data
|   |-- avlegs
|   |   |-- bdypoly.avl
|   |   |-- boundary.avl
|   |   |-- bridge.avl
|   |   |-- copy of bdypoly.avl
|   |   |-- disttext.avl
|   |   |-- index.avl
|   |   |-- insert.avl
|   |   |-- roadsym.avl
|   |   |-- roadtxt.avl
|   |   |-- symline.avl
|   |   |-- sympt.avl
|   |   |-- symtext.avl
|   |   |-- utility.avl
|   |   |-- waterline.avl
|   |   `-- waterpoly.avl
|   |-- cntyview.apr
|   |-- library
|   |   |-- accomack			# accomack is a county name.  On the CD, this
|   |   |   |-- boundary	# dir structure is repeated for each county.
|   |   |   |   |-- aat.adf
|   |   |   |   |-- arc.adf
|   |   |   |   |-- arx.adf
|   |   |   |   |-- cnt.adf
|   |   |   |   |-- cnx.adf
|   |   |   |   |-- dblbnd.adf
|   |   |   |   |-- dbltic.adf
|   |   |   |   |-- lab.adf
|   |   |   |   |-- log
|   |   |   |   |-- nat.adf
|   |   |   |   |-- pal.adf
|   |   |   |   |-- par.adf
|   |   |   |   |-- pat.adf
|   |   |   |   |-- pax.adf
|   |   |   |   `-- prj.adf
|   |   |   |-- bridge
|   |   |   |   |-- aat.adf
|   |   |   |   |-- arc.adf
|   |   |   |   |-- arx.adf
|   |   |   |   |-- dblbnd.adf
|   |   |   |   |-- dbltic.adf
|   |   |   |   |-- log
|   |   |   |   |-- nat.adf
|   |   |   |   |-- par.adf
|   |   |   |   `-- prj.adf
|   |   |   |-- distance
|   |   |   |   |-- dblbnd.adf
|   |   |   |   |-- dbltic.adf
|   |   |   |   |-- main.tat
|   |   |   |   |-- main.txt
|   |   |   |   |-- main.txx
|   |   |   |   |-- prj.adf
|   |   |   |   |-- small.tat
|   |   |   |   |-- small.txt
|   |   |   |   `-- small.txx
|   |   |   |-- info
|   |   |   |   |-- arc.dir
|   |   |   |   |-- arc0000.dat
|   |   |   |   |-- arc0000.nit
|   |   |   |   |-- arc0001.dat
|   |   |   |   |-- arc0001.nit
|   |   |   |   |-- arc0002.dat
|   |   |   |   |-- arc0002.nit
|   |   |   |   |-- arc0004.dat
|   |   |   |   |-- arc0004.nit
|   |   |   |   |-- arc0005.dat
|   |   |   |   |-- arc0005.nit
|   |   |   |   |-- arc0006.dat
|   |   |   |   |-- arc0006.nit
|   |   |   |   |-- arc0007.dat
|   |   |   |   |-- arc0007.nit
|   |   |   |   |-- arc0008.dat
|   |   |   |   |-- arc0008.nit
|   |   |   |   |-- arc0009.dat
|   |   |   |   |-- arc0009.nit
|   |   |   |   |-- arc0010.dat
|   |   |   |   |-- arc0010.nit
|   |   |   |   |-- arc0011.dat
|   |   |   |   |-- arc0011.nit
|   |   |   |   |-- arc0012.dat
|   |   |   |   |-- arc0012.nit
|   |   |   |   |-- arc0013.dat
|   |   |   |   |-- arc0013.nit
|   |   |   |   |-- arc0014.dat
|   |   |   |   |-- arc0014.nit
|   |   |   |   |-- arc0015.dat
|   |   |   |   |-- arc0015.nit
|   |   |   |   |-- arc0016.dat
|   |   |   |   |-- arc0016.nit
|   |   |   |   |-- arc0017.dat
|   |   |   |   |-- arc0017.nit
|   |   |   |   |-- arc0018.dat
|   |   |   |   |-- arc0018.nit
|   |   |   |   |-- arc0019.dat
|   |   |   |   |-- arc0019.nit
|   |   |   |   |-- arc0020.dat
|   |   |   |   |-- arc0020.nit
|   |   |   |   |-- arc0021.dat
|   |   |   |   |-- arc0021.nit
|   |   |   |   |-- arc0022.dat
|   |   |   |   |-- arc0022.nit
|   |   |   |   |-- arc0023.dat
|   |   |   |   |-- arc0023.nit
|   |   |   |   |-- arc0024.dat
|   |   |   |   |-- arc0024.nit
|   |   |   |   |-- arc0025.dat
|   |   |   |   |-- arc0025.nit
|   |   |   |   |-- arc0028.dat
|   |   |   |   |-- arc0028.nit
|   |   |   |   |-- arc0029.dat
|   |   |   |   |-- arc0029.nit
|   |   |   |   |-- arc0031.dat
|   |   |   |   |-- arc0031.nit
|   |   |   |   |-- arc0032.dat
|   |   |   |   |-- arc0032.nit
|   |   |   |   |-- arc0033.dat
|   |   |   |   |-- arc0033.nit
|   |   |   |   |-- arc0034.dat
|   |   |   |   |-- arc0034.nit
|   |   |   |   |-- arc0035.dat
|   |   |   |   |-- arc0035.nit
|   |   |   |   |-- arc0036.dat
|   |   |   |   |-- arc0036.nit
|   |   |   |   |-- arc0037.dat
|   |   |   |   |-- arc0037.nit
|   |   |   |   |-- arc0038.dat
|   |   |   |   |-- arc0038.nit
|   |   |   |   |-- arc0039.dat
|   |   |   |   |-- arc0039.nit
|   |   |   |   |-- arc0040.dat
|   |   |   |   |-- arc0040.nit
|   |   |   |   |-- arc0041.dat
|   |   |   |   |-- arc0041.nit
|   |   |   |   |-- arc0042.dat
|   |   |   |   |-- arc0042.nit
|   |   |   |   |-- arc0045.dat
|   |   |   |   |-- arc0045.nit
|   |   |   |   |-- arc0046.dat
|   |   |   |   `-- arc0046.nit
|   |   |   |-- insert
|   |   |   |   |-- aat.adf
|   |   |   |   |-- arc.adf
|   |   |   |   |-- arx.adf
|   |   |   |   |-- cnt.adf
|   |   |   |   |-- cnx.adf
|   |   |   |   |-- dblbnd.adf
|   |   |   |   |-- dbltic.adf
|   |   |   |   |-- lab.adf
|   |   |   |   |-- log
|   |   |   |   |-- nat.adf
|   |   |   |   |-- pal.adf
|   |   |   |   |-- par.adf
|   |   |   |   |-- pat.adf
|   |   |   |   `-- pax.adf
|   |   |   |-- roads
|   |   |   |   |-- aat.adf
|   |   |   |   |-- arc.adf
|   |   |   |   |-- arx.adf
|   |   |   |   |-- cnt.adf
|   |   |   |   |-- cnx.adf
|   |   |   |   |-- dblbnd.adf
|   |   |   |   |-- dbltic.adf
|   |   |   |   |-- lab.adf
|   |   |   |   |-- log
|   |   |   |   |-- main.tat
|   |   |   |   |-- main.txt
|   |   |   |   |-- main.txx
|   |   |   |   |-- nat.adf
|   |   |   |   |-- pal.adf
|   |   |   |   |-- par.adf
|   |   |   |   |-- pat.adf
|   |   |   |   |-- pax.adf
|   |   |   |   |-- prj.adf
|   |   |   |   |-- small.tat
|   |   |   |   |-- small.txt
|   |   |   |   `-- small.txx
|   |   |   |-- symbols
|   |   |   |   |-- aat.adf
|   |   |   |   |-- arc.adf
|   |   |   |   |-- arx.adf
|   |   |   |   |-- dblbnd.adf
|   |   |   |   |-- dbltic.adf
|   |   |   |   |-- lab.adf
|   |   |   |   |-- log
|   |   |   |   |-- main.tat
|   |   |   |   |-- main.txt
|   |   |   |   |-- main.txx
|   |   |   |   |-- par.adf
|   |   |   |   |-- pat.adf
|   |   |   |   |-- prj.adf
|   |   |   |   |-- small.tat
|   |   |   |   |-- small.txt
|   |   |   |   `-- small.txx
|   |   |   |-- utility
|   |   |   |   |-- aat.adf
|   |   |   |   |-- arc.adf
|   |   |   |   |-- arx.adf
|   |   |   |   |-- dblbnd.adf
|   |   |   |   |-- dbltic.adf
|   |   |   |   |-- log
|   |   |   |   |-- nat.adf
|   |   |   |   |-- par.adf
|   |   |   |   `-- prj.adf
|   |   |   `-- water
|   |   |       |-- aat.adf
|   |   |       |-- arc.adf
|   |   |       |-- arx.adf
|   |   |       |-- cnt.adf
|   |   |       |-- cnx.adf
|   |   |       |-- dblbnd.adf
|   |   |       |-- dbltic.adf
|   |   |       |-- lab.adf
|   |   |       |-- log
|   |   |       |-- nat.adf
|   |   |       |-- pal.adf
|   |   |       |-- par.adf
|   |   |       |-- pat.adf
|   |   |       |-- pax.adf
|   |   |       `-- prj.adf
|   |   |-- tiles
|   |   |-- virginia_beach
|   |   |   |-- boundary
|   |   |   |   |-- aat.adf
|   |   |   |   |-- arc.adf
|   |   |   |   |-- arx.adf
|   |   |   |   |-- cnt.adf
|   |   |   |   |-- cnx.adf
|   |   |   |   |-- dblbnd.adf
|   |   |   |   |-- dbltic.adf
|   |   |   |   |-- lab.adf
|   |   |   |   |-- log
|   |   |   |   |-- nat.adf
|   |   |   |   |-- pal.adf
|   |   |   |   |-- par.adf
|   |   |   |   |-- pat.adf
|   |   |   |   |-- pax.adf
|   |   |   |   `-- prj.adf
|   |   |   |-- bridge
|   |   |   |   |-- aat.adf
|   |   |   |   |-- arc.adf
|   |   |   |   |-- arx.adf
|   |   |   |   |-- dblbnd.adf
|   |   |   |   |-- dbltic.adf
|   |   |   |   |-- log
|   |   |   |   |-- nat.adf
|   |   |   |   |-- par.adf
|   |   |   |   `-- prj.adf
|   |   |   |-- distance
|   |   |   |   |-- dblbnd.adf
|   |   |   |   |-- dbltic.adf
|   |   |   |   |-- main.tat
|   |   |   |   |-- main.txt
|   |   |   |   |-- main.txx
|   |   |   |   |-- prj.adf
|   |   |   |   |-- small.tat
|   |   |   |   |-- small.txt
|   |   |   |   `-- small.txx
|   |   |   |-- info
|   |   |   |   |-- arc.dir
|   |   |   |   |-- arc0000.dat
|   |   |   |   |-- arc0000.nit
|   |   |   |   |-- arc0001.dat
|   |   |   |   |-- arc0001.nit
|   |   |   |   |-- arc0002.dat
|   |   |   |   |-- arc0002.nit
|   |   |   |   |-- arc0003.dat
|   |   |   |   |-- arc0003.nit
|   |   |   |   |-- arc0004.dat
|   |   |   |   |-- arc0004.nit
|   |   |   |   |-- arc0005.dat
|   |   |   |   |-- arc0005.nit
|   |   |   |   |-- arc0006.dat
|   |   |   |   |-- arc0006.nit
|   |   |   |   |-- arc0007.dat
|   |   |   |   |-- arc0007.nit
|   |   |   |   |-- arc0008.dat
|   |   |   |   |-- arc0008.nit
|   |   |   |   |-- arc0009.dat
|   |   |   |   |-- arc0009.nit
|   |   |   |   |-- arc0010.dat
|   |   |   |   |-- arc0010.nit
|   |   |   |   |-- arc0011.dat
|   |   |   |   |-- arc0011.nit
|   |   |   |   |-- arc0012.dat
|   |   |   |   |-- arc0012.nit
|   |   |   |   |-- arc0013.dat
|   |   |   |   |-- arc0013.nit
|   |   |   |   |-- arc0014.dat
|   |   |   |   |-- arc0014.nit
|   |   |   |   |-- arc0015.dat
|   |   |   |   |-- arc0015.nit
|   |   |   |   |-- arc0016.dat
|   |   |   |   |-- arc0016.nit
|   |   |   |   |-- arc0017.dat
|   |   |   |   |-- arc0017.nit
|   |   |   |   |-- arc0018.dat
|   |   |   |   |-- arc0018.nit
|   |   |   |   |-- arc0019.dat
|   |   |   |   |-- arc0019.nit
|   |   |   |   |-- arc0020.dat
|   |   |   |   |-- arc0020.nit
|   |   |   |   |-- arc0022.dat
|   |   |   |   |-- arc0022.nit
|   |   |   |   |-- arc0024.dat
|   |   |   |   |-- arc0024.nit
|   |   |   |   |-- arc0027.dat
|   |   |   |   |-- arc0027.nit
|   |   |   |   |-- arc0029.dat
|   |   |   |   |-- arc0029.nit
|   |   |   |   |-- arc0030.dat
|   |   |   |   |-- arc0030.nit
|   |   |   |   |-- arc0031.dat
|   |   |   |   |-- arc0031.nit
|   |   |   |   |-- arc0032.dat
|   |   |   |   |-- arc0032.nit
|   |   |   |   |-- arc0034.dat
|   |   |   |   |-- arc0034.nit
|   |   |   |   |-- arc0035.dat
|   |   |   |   |-- arc0035.nit
|   |   |   |   |-- arc0036.dat
|   |   |   |   |-- arc0036.nit
|   |   |   |   |-- arc0037.dat
|   |   |   |   |-- arc0037.nit
|   |   |   |   |-- arc0038.dat
|   |   |   |   |-- arc0038.nit
|   |   |   |   |-- arc0039.dat
|   |   |   |   `-- arc0039.nit
|   |   |   |-- roads
|   |   |   |   |-- aat.adf
|   |   |   |   |-- arc.adf
|   |   |   |   |-- arx.adf
|   |   |   |   |-- cnt.adf
|   |   |   |   |-- cnx.adf
|   |   |   |   |-- dblbnd.adf
|   |   |   |   |-- dbltic.adf
|   |   |   |   |-- lab.adf
|   |   |   |   |-- log
|   |   |   |   |-- main.tat
|   |   |   |   |-- main.txt
|   |   |   |   |-- main.txx
|   |   |   |   |-- nat.adf
|   |   |   |   |-- pal.adf
|   |   |   |   |-- par.adf
|   |   |   |   |-- pat.adf
|   |   |   |   |-- pax.adf
|   |   |   |   |-- prj.adf
|   |   |   |   |-- small.tat
|   |   |   |   |-- small.txt
|   |   |   |   `-- small.txx
|   |   |   |-- symbols
|   |   |   |   |-- aat.adf
|   |   |   |   |-- arc.adf
|   |   |   |   |-- arx.adf
|   |   |   |   |-- dblbnd.adf
|   |   |   |   |-- dbltic.adf
|   |   |   |   |-- lab.adf
|   |   |   |   |-- log
|   |   |   |   |-- main.tat
|   |   |   |   |-- main.txt
|   |   |   |   |-- main.txx
|   |   |   |   |-- par.adf
|   |   |   |   |-- pat.adf
|   |   |   |   |-- prj.adf
|   |   |   |   |-- small.tat
|   |   |   |   |-- small.txt
|   |   |   |   `-- small.txx
|   |   |   |-- utility
|   |   |   |   |-- aat.adf
|   |   |   |   |-- arc.adf
|   |   |   |   |-- arx.adf
|   |   |   |   |-- dblbnd.adf
|   |   |   |   |-- dbltic.adf
|   |   |   |   |-- log
|   |   |   |   |-- nat.adf
|   |   |   |   |-- par.adf
|   |   |   |   `-- prj.adf
|   |   |   `-- water
|   |   |       |-- aat.adf
|   |   |       |-- arc.adf
|   |   |       |-- arx.adf
|   |   |       |-- cnt.adf
|   |   |       |-- cnx.adf
|   |   |       |-- dblbnd.adf
|   |   |       |-- dbltic.adf
|   |   |       |-- lab.adf
|   |   |       |-- log
|   |   |       |-- nat.adf
|   |   |       |-- pal.adf
|   |   |       |-- par.adf
|   |   |       |-- pat.adf
|   |   |       |-- pax.adf
|   |   |       `-- prj.adf
|   |-- projects
|   |   |-- c
|   |   |   |-- accomack.aep
|   |   |   `-- # repeated for each county
|   |   |-- d
|   |   |   |-- accomack.aep
|   |   `-- e
|   |       |-- accomack.aep
|   `-- statewide
|       |-- boundary
|       |   |-- aat.adf
|       |   |-- arc.adf
|       |   |-- arx.adf
|       |   |-- cnt.adf
|       |   |-- cnx.adf
|       |   |-- dblbnd.adf
|       |   |-- dbltic.adf
|       |   |-- lab.adf
|       |   |-- log
|       |   |-- nat.adf
|       |   |-- pal.adf
|       |   |-- par.adf
|       |   |-- pat.adf
|       |   |-- pax.adf
|       |   `-- prj.adf
|       |-- bridge
|       |   |-- aat.adf
|       |   |-- arc.adf
|       |   |-- arx.adf
|       |   |-- dblbnd.adf
|       |   |-- dbltic.adf
|       |   |-- log
|       |   |-- nat.adf
|       |   `-- prj.adf
|       |-- distance
|       |   |-- dblbnd.adf
|       |   |-- dbltic.adf
|       |   |-- log
|       |   |-- main.tat
|       |   |-- main.txt
|       |   |-- main.txx
|       |   |-- prj.adf
|       |   |-- small.tat
|       |   |-- small.txt
|       |   `-- small.txx
|       |-- info
|       |   |-- arc.dir
|       |   |-- arc0000.dat
|       |   |-- arc0000.nit
|       |   |-- arc0001.dat
|       |   |-- arc0001.nit
|       |   |-- arc0002.dat
|       |   |-- arc0002.nit
|       |   |-- arc0003.dat
|       |   |-- arc0003.nit
|       |   |-- arc0004.dat
|       |   |-- arc0004.nit
|       |   |-- arc0005.dat
|       |   |-- arc0005.nit
|       |   |-- arc0006.dat
|       |   |-- arc0006.nit
|       |   |-- arc0007.dat
|       |   |-- arc0007.nit
|       |   |-- arc0008.dat
|       |   |-- arc0008.nit
|       |   |-- arc0009.dat
|       |   |-- arc0009.nit
|       |   |-- arc0010.dat
|       |   |-- arc0010.nit
|       |   |-- arc0011.dat
|       |   |-- arc0011.nit
|       |   |-- arc0012.dat
|       |   |-- arc0012.nit
|       |   |-- arc0013.dat
|       |   |-- arc0013.nit
|       |   |-- arc0014.dat
|       |   |-- arc0014.nit
|       |   |-- arc0015.dat
|       |   |-- arc0015.nit
|       |   |-- arc0016.dat
|       |   |-- arc0016.nit
|       |   |-- arc0017.dat
|       |   |-- arc0017.nit
|       |   |-- arc0018.dat
|       |   |-- arc0018.nit
|       |   |-- arc0019.dat
|       |   |-- arc0019.nit
|       |   |-- arc0020.dat
|       |   |-- arc0020.nit
|       |   |-- arc0021.dat
|       |   |-- arc0021.nit
|       |   |-- arc0022.dat
|       |   |-- arc0022.nit
|       |   |-- arc0023.dat
|       |   |-- arc0023.nit
|       |   |-- arc0024.dat
|       |   |-- arc0024.nit
|       |   |-- arc0025.dat
|       |   |-- arc0025.nit
|       |   |-- arc0027.dat
|       |   |-- arc0027.nit
|       |   |-- arc0028.dat
|       |   |-- arc0028.nit
|       |   |-- arc0029.dat
|       |   |-- arc0029.nit
|       |   |-- arc0030.dat
|       |   |-- arc0030.nit
|       |   |-- arc0031.dat
|       |   |-- arc0031.nit
|       |   |-- arc0032.dat
|       |   |-- arc0032.nit
|       |   |-- arc0035.dat
|       |   |-- arc0035.nit
|       |   |-- arc0036.dat
|       |   |-- arc0036.nit
|       |   |-- arc0037.dat
|       |   |-- arc0037.nit
|       |   |-- arc0038.dat
|       |   |-- arc0038.nit
|       |   |-- arc0039.dat
|       |   |-- arc0039.nit
|       |   |-- arc0040.dat
|       |   |-- arc0040.nit
|       |   |-- arc0041.dat
|       |   |-- arc0041.nit
|       |   |-- arc0046.dat
|       |   |-- arc0046.nit
|       |   |-- arc0047.dat
|       |   |-- arc0047.nit
|       |   |-- arc0048.dat
|       |   |-- arc0048.nit
|       |   |-- arc0049.dat
|       |   |-- arc0049.nit
|       |   |-- arc0050.dat
|       |   |-- arc0050.nit
|       |   |-- arc0051.dat
|       |   |-- arc0051.nit
|       |   |-- arc0052.dat
|       |   `-- arc0052.nit
|       |-- remove
|       |   |-- aat.adf
|       |   |-- arc.adf
|       |   |-- arx.adf
|       |   |-- cnt.adf
|       |   |-- cnx.adf
|       |   |-- dblbnd.adf
|       |   |-- dbltic.adf
|       |   |-- lab.adf
|       |   |-- log
|       |   |-- main.tat
|       |   |-- main.txt
|       |   |-- main.txx
|       |   |-- nat.adf
|       |   |-- pal.adf
|       |   |-- par.adf
|       |   |-- pat.adf
|       |   |-- pax.adf
|       |   |-- prj.adf
|       |   |-- small.tat
|       |   |-- small.txt
|       |   `-- small.txx
|       |-- restrict
|       |   |-- aat.adf
|       |   |-- arc.adf
|       |   |-- arx.adf
|       |   |-- dblbnd.adf
|       |   |-- dbltic.adf
|       |   |-- nat.adf
|       |   `-- prj.adf
|       |-- roads
|       |   |-- aat.adf
|       |   |-- arc.adf
|       |   |-- arx.adf
|       |   |-- cnt.adf
|       |   |-- cnx.adf
|       |   |-- dblbnd.adf
|       |   |-- dbltic.adf
|       |   |-- lab.adf
|       |   |-- log
|       |   |-- main.tat
|       |   |-- main.txt
|       |   |-- main.txx
|       |   |-- nat.adf
|       |   |-- pal.adf
|       |   |-- par.adf
|       |   |-- pat.adf
|       |   |-- pax.adf
|       |   |-- prj.adf
|       |   |-- small.tat
|       |   |-- small.txt
|       |   `-- small.txx
|       |-- symbols
|       |   |-- aat.adf
|       |   |-- arc.adf
|       |   |-- arx.adf
|       |   |-- dblbnd.adf
|       |   |-- dbltic.adf
|       |   |-- lab.adf
|       |   |-- log
|       |   |-- main.tat
|       |   |-- main.txt
|       |   |-- main.txx
|       |   |-- pat.adf
|       |   |-- prj.adf
|       |   |-- small.tat
|       |   |-- small.txt
|       |   `-- small.txx
|       |-- utility
|       |   |-- aat.adf
|       |   |-- arc.adf
|       |   |-- arx.adf
|       |   |-- dblbnd.adf
|       |   |-- dbltic.adf
|       |   |-- log
|       |   |-- nat.adf
|       |   `-- prj.adf
|       `-- water
|           |-- aat.adf
|           |-- arc.adf
|           |-- arx.adf
|           |-- cnt.adf
|           |-- cnx.adf
|           |-- dblbnd.adf
|           |-- dbltic.adf
|           |-- lab.adf
|           |-- log
|           |-- nat.adf
|           |-- pal.adf
|           |-- par.adf
|           |-- pat.adf
|           |-- pax.adf
|           `-- prj.adf
|-- fonts
|   |-- vdotmrk.avp
|   `-- windows
|       |-- ntfonts.lnk
|       |-- univb___.ttf
|       |-- univbo__.ttf
|       |-- univc___.ttf
|       |-- univcb__.ttf
|       |-- univcbo_.ttf
|       |-- univco__.ttf
|       |-- univers_.ttf
|       |-- univo___.ttf
|       |-- vdotn___.ttf
|       `-- win95fonts.lnk
|-- html
|   |-- ainotes.html
|   |-- altsources.html
|   |-- arcexplorer.html
|   |-- avnotes.html
|   |-- avnotes2.html
|   |-- creator.html
|   |-- datamodel.txt
|   |-- enhanced.html
|   |-- important.html
|   |-- metadata.html
|   |-- newroads.htm
|   |-- overview.html
|   |-- project.html
|   |-- specs.html
|   |-- statement.html
|   `-- system.html
|-- images
|-- index.htm
|-- support
|   |-- vanorth.prj
|   `-- vasouth.prj
`-- system
    |-- arcinfo
    |   |-- fonts
    |   |   |-- uv.pfb
    |   |   |-- uvb.pfb
    |   |   |-- uvbo.pfb
    |   |   |-- uvc.pfb
    |   |   |-- uvcb.pfb
    |   |   |-- uvcbo.pfb
    |   |   |-- uvcdo.pfb
    |   |   `-- uvo.pfb
    |   |-- igl63exe
    |   |   `-- fnt039
    |   |-- locale
    |   |   `-- c
    |   |       |-- codeset
    |   |       `-- fontindex
    |   `-- symbols
    |       |-- vdot.lin
    |       |-- vdot.mrk
    |       `-- vdot.txt
    `-- windows
        |-- autoexec.lnk
        `-- ntsystem.lnk
1091 directories, 20789 files
