[GRASSLIST:2649] Some export questions
Soil & Water Lab. swlab at cornell.edu
Tue Nov 13 10:54:17 EST 2001
Hello GRASS users,
I have some questions concerning output in different format :I have a raster
DEM I would like to insert in a LaTeX document (so, I'd need either a PNG or
a .ps)
* Is there any way to bypass the 8bit color limitation with the PNG or CELL
drivers ? Noting that a command like
"r.out.ppm input=MyMap output=- | pnmtopng > MyMap.png"
does not present any color limitation, but does not allow to export overlying
elements.
* When using CELL or PNG, a bar scale created by "d.barscale" seems deformed
(the dashes seem shifted). Is this a pb of my configuration, or a bug ?
* How can I export a legend created with "d.leg.thin -s" to a PNG file
without losing colors (that is, without using a CELL or PNG, still because of
the 8bit limitation) ?
* How can I create a gradient legend in postscript ? It seems that ps.map
allows only the creation of a colortable, which is quite overwhelming with
maps having a lot of categories (a DEM for example).
* How can I create a bar scale (or any other scale) in postscript ?
Soil and Water Laboratory
Biological and Environmental Engineering Department
Cornell University
Riley-Robb Hall
ITHACA, NY 14853 - USA
