[GRASSLIST:2654] Re: About SGI
Andreas Lange Andreas.Lange at Rhein-Main.de
Tue Nov 13 14:25:05 EST 2001
Hi Manuel,
Alpiste wrote:
> dear all:
> I'd like to install GRASS into a Silicon Graphics Octane2 running under
> IRIX 6.5. did anyone install this software in similar machines?.. If
> yes.... is there any particular fact to do installing GRASS?..
> Thanks a lot in advance
> Alpiste
which version do you plan to install?
GRASS 5 from CVS should compile out of the box on IRIX 6.5. Look into
the REQUIREMENTS file, you can get the needed libraries mostly from
freeware.sgi.com (needs root permissions on the machine to install). Do
you have a license for the MIPS PRO compiler of SGI?
If you can not compile yourself, you could install a binary, but
currently there is none on the server.
One thing to remember: If you are on a IRIX64 machine and compile in
native 64bit mode, your vector files will not be portable. If you need
more information, please ask more specific questions, i'll dig out more
then.
HTH,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
url: http://mitglied.tripod.de/AndreasLange
mail: Andreas.Lange_at_Rhein-Main.de - A.C.Lange_at_GMX.net
