[GRASSLIST:2658] Re: Need help with v.patch
Ben Logan blogan at newcreature.org
Tue Nov 13 21:58:43 EST 2001
Just wondered if no-one saw my posting, or if no-one knows the answer.
Regards,
Ben
On Mon, Nov 12, 2001 at 11:58:48AM -0500, Ben Logan wrote:
> Hello,
> I grabbed some 24k USGS SDTS DLGs from the gisdatadepot, and wanted to
> v.patch them together.  I've done this same thing with the
> corresponding DEMs and r.patch.  The problem is that the USGS
> apparently used the same labels for the vectors in different
> quadrangles, so v.patch complains about duplicate labels, and the
> resulting vector map contains only the vectors from the first map
> specified on the command line.
> Is there a way to overcome this problem?
> Thanks,
> Ben
Ben Logan: blogan at newcreature dot org
OpenPGP Key KeyID: A1ADD1F0
