[GRASSLIST:2607] re:g.select.pg
Glynn Clements
glynn.clements at virgin.net
Thu Oct 25 19:53:45 EDT 2001
Sjors wrote:
> Well the problem is as follows. When selecting g.select.pg (I"ve wrote
> it down wrong the first time) within GUI, I can fill in servername and
> database. Then I get the following statement:
> Couldn't execute g.select.pg no such directory or program.
> This happened with compiling and the install of the new binaries.
Note that, until a few days ago, the Postgres programs weren't built
automatically. You had to execute additional commands, which were
displayed at the end of the "make" process.
> With ./configure --with-postgresql-includes=/usr/include/pgsql is
> doesn't seem to find the header file.
The option is called "--with-postgres-includes", not
"--with-postgresql-includes" (no "ql").
> Does compile won't install.
Details? AFAIK, "make install" cannot fail. If it doesn't install
certain files, it is because they weren't built.
> I've
> got the binaries now. Everything seems to be oke (RedHat7.2).
> Well I've found the answer. The command is located in
> /usr/local/grass5/etc/bin/cmd. This doesn't seem to be in the path.
It isn't meant to be. Nearly all of the "visible" commands (the ones
in $GISBASE/bin) are hard links to $GISBASE/etc/front.end. This
program invokes the corresponding program from $GISBASE/etc/bin/cmd or
$GISBASE/etc/bin/inter, depending upon whether any arguments are given
and whether there is a specific interactive version of the command.
If you have $GISBASE/etc/bin/cmd/g.select.pg but don't have
$GISBASE/bin/g.select.pg, it is probable that you forgot to run
"gmakelinks5" following "gmake5 src.garden/grass.postgresql".
Glynn Clements <glynn.clements at virgin.net>
