[GRASSLIST:2382] s.proj question
    Kevin Slover
    kjslover at nhc.noaa.gov
    Tue Sep  4 10:46:13 EDT 2001
I am using the s.proj command to reproject some site data, and I am
curious to the conversion method used.  I am going from nad83 degrees
(decimal) format to state plane coordinate.  Is it using something
similar to CORPSON available from the National Geodetic Survey, or is an
internal program developed by the GRASS programmer??  Thanks...
LTJG Kevin Slover, NOAA
GIS Specialist/Meteorologist/Oceanographer
Tropical Prediction Center / Technical Support Branch
11691 SW 17th St  Miami FL  33165
(W) 305-229-4456  (F) 305-553-1264
