[GRASSLIST:2412] Re: "Invalid resource file" error
Robert Najlis
rnajlis at indiana.edu
Sat Sep 8 21:59:03 EDT 2001
I am running GRASS on OSX I have GRASS in the Applications directory, so
it is /Applications/GRASS
I don't use /opt or anything like that, Spearfish is in the GRASS
directory, so it looks like this: /Applications/GRASS/spearfish
My set up in GRASS is this:
locations)
MAPSET: PERMANENT_____ (or mapsets within a location)
DATABASE: /Applications/GRASS_______________________________
hope this helps.
Robert Najlis
On Sat, 8 Sep 2001, Aurelien wrote:
> I get this strange error when launching grass5 for the first time:
> Error opening terminal: vt100.
> Invalid resource file, removing /Users/candide/.grassrc5
> I'm on Mac OS X (can't wait to get Jeshua's CD ;-)
> I tried from within a Xterm (XDarwin), but then the first message
> becomes:
> Error opening terminal: xterm
> On the first error, the readme tells that you shoud go to /opt, and then
> do 'grass5 spearfish/PERMANENT'.
> But I don't have /opt (should the install script have made one for me ?,
> or did I miss an install step ?). So I created a /opt dir and inside it
> a spearfish dir. However, that did't help much: now I get:
> Starting GRASS ...
> /opt/spearfish/PERMANENT: No such location
> Somebody else experienced the same frustation ?
> Aurélien
=== Robert Najlis
)~ rnajlis at indiana.edu
|\| http://php.indiana.edu/~rnajlis
