[GRASSLIST:2420] Re: more startup woes
    jeshua
    jeshua at SierraMaps.com
    Tue Sep 11 07:02:11 EDT 2001
On Monday, September 10, 2001, at 08:19 AM, Glynn Clements wrote:
> Note: beta11 is quite out of date now.
Markus - what is the FTP address to upload the Pre binaries to?
>> There, the terminal tells me I've got several options:
>> This version running thru the TC Shell (/bin/tcsh)
>> Help is available with the command:      g.help
>> See the licence terms with:              g.version -c
>> Start the graphical user interface with: tcltkgrass&
>> When ready to quit enter:                exit
>> Funny thing, if I do g.help, I'm back with the 'vt100 error'.
> g.help is a curses-based program. Error messages of the form "Error
> opening terminal: xxxx" are generated by the curses library when it
> can't find a terminal description.
> This problem seems to be common on MacOS X.
It was either fixed with OS X 10.0.4 or Grass Pre 1 or the combination
of both....
Cheers,
Jeshua Lacock                                http://OpenOSX.com
Programmer/Owner                     http://SierraMaps.com
Phone: (760) 935-4736            http://3dTopoMaps.com
