[GRASSLIST:2417] Re: more startup woes
Glynn Clements
glynn.clements at virgin.net
Mon Sep 10 11:19:55 EDT 2001
Aurelien wrote:
> First of all, thanks buddies for your answers. Seems like it's hard to
> get started with GRASS !
GRASS is basically Unix software. MacOS X is a fairly recent addition
to the Unix family, and isn't yet well understood by most Unix
developers.
> BTW, I had to manually add /usr/local/bin to my PATH. Is this normal?
It's fairly common to have to do this. Ultimately, there isn't much
point in having /usr/local/bin if it isn't in $PATH.
> Now, if I cd to /opt and do 'grass5 spearfish/PERMANENT', yes, I get a
> 'GRASS 5.0beta11 >' prompt
Note: beta11 is quite out of date now.
> There, the terminal tells me I've got several options:
> This version running thru the TC Shell (/bin/tcsh)
> Help is available with the command: g.help
> See the licence terms with: g.version -c
> Start the graphical user interface with: tcltkgrass&
> When ready to quit enter: exit
> Funny thing, if I do g.help, I'm back with the 'vt100 error'.
g.help is a curses-based program. Error messages of the form "Error
opening terminal: xxxx" are generated by the curses library when it
can't find a terminal description.
This problem seems to be common on MacOS X.
> g.version
> -c works though (Great !), and exit works also. However, if I enter
> 'tcltkgrass&', I get the following message:
> [1] 747
> Mapset <PERMANENT> in Location
> <spearfish> GRASS 5.0beta11 >
> /usr/local/grass5/bin/tcltkgrass: command not found: wish [3]
> What is 'wish' now ?
"wish" is the Tcl/Tk shell. You need Tcl/Tk to run tcltkgrass, NVIZ,
and a couple of other components, but you can live without it
otherwise.
If you have wish installed under a different name (e.g. wish8.3),
either create a symlink, or set the GRASS_WISH environment variable to
the pathname of the wish executable.
Glynn Clements <glynn.clements at virgin.net>
