[GRASSLIST:2433] Re: Grass5pre2. Compilation problem on RedHat 7.1
    Markus Neteler
    neteler at itc.it
    Mon Sep 17 08:52:55 EDT 2001
Hi Daniel,
On Mon, Sep 17, 2001 at 09:04:38AM +0200, Daniel Tourde wrote:
> Hi!
> I have tried to compile Grass5pre 2 on my RedHat7.1 box (Intel) without
> success. I have the following error message:
> + cd src.garden/grass.postgresql
> + /usr/local/bin/gmake5
>   SRC     = /usr/src/redhat/BUILD/grass5.0.0pre2/src
>   CMD     = /usr/src/redhat/BUILD/grass5.0.0pre2/src/CMD
>   UNUSED  = /usr/src/redhat/BUILD/grass5.0.0pre2/unused
>   HEADER  = head.i686-pc-linux-gnu
>   ARCH    = i686-pc-linux-gnu
>   GISBASE = /usr/src/redhat/BUILD/grass5.0.0pre2/dist.i686-pc-linux-gnu
>   VERSION = 5.0.0pre2 September 2001
> /usr/src/redhat/BUILD/grass5.0.0pre2/src.garden/grass.postgresql
>   mkdir OBJ.i686-pc-linux-gnu
>   make -f OBJ.i686-pc-linux-gnu/make.rules
> /usr/local/bin/gmake5 d.rast.pg
> /usr/src/redhat/BUILD/grass5.0.0pre2/src.garden/grass.postgresql/d.rast.pg
> make[1]: Entering directory
> `/usr/src/redhat/BUILD/grass5.0.0pre2/src.garden/gra
> ss.postgresql/d.rast.pg'
> gcc -g -O2  -I/usr/src/redhat/BUILD/grass5.0.0pre2/src/include   -c
> main.c -o OB
> J.i686-pc-linux-gnu/main.o
> getAllOpts.c
>  -o OBJ.i686-pc-linux-gnu/getAllOpts.o
> getSopts.c -
> o OBJ.i686-pc-linux-gnu/getSopts.o
> buildInfxQry
> .c -o OBJ.i686-pc-linux-gnu/buildInfxQry.o
> runInfxFile.
> c -o OBJ.i686-pc-linux-gnu/runInfxFile.o
> runInfxFile.c:6:22: libpq-fe.h: No such file or directory
This is a file from PostgreSQL. You will have received a PostgreSQL
warning from "configure" that libpq-fe.h is missing. After completely
installing the PostgreSQL header files you will be able to
compile.
Hope this helps,
 Markus Neteler
