[GRASSLIST:2436] Re: Grass5pre2. Compilation problem on RedHat 7.1
    Daniel Tourde
    ted at foi.se
    Mon Sep 17 09:36:04 EDT 2001
Hi!
> > gcc -g -O2  -I/usr/src/redhat/BUILD/grass5.0.0pre2/src/include   -c
> > runInfxFile.
> > c -o OBJ.i686-pc-linux-gnu/runInfxFile.o
> > runInfxFile.c:6:22: libpq-fe.h: No such file or directory
> This is a file from PostgreSQL. You will have received a PostgreSQL
> warning from "configure" that libpq-fe.h is missing. After completely
> installing the PostgreSQL header files you will be able to
I checked on my system (RedHat 7.1, Intel).
[root at brest root]# locate libpq-fe.h
/usr/include/pgsql/libpq-fe.h
[root at brest root]# rpm -qa | grep postgres
postgresql-server-7.0.3-8
postgresql-7.0.3-8
postgresql-devel-7.0.3-8
libpq-fe.h is there. I don't understand why it is not found then.
		Daniel
Daniel TOURDE                             E-mail : daniel.tourde at foi.se
                                             Tel : +46 (0)8-55 50 43 44
                                        Cellular :  +46 (0)70-849 93 40
   FOI, Swedish Defence Research Agency; Aeronautics Division - FFA
       Dept. of Wind Energy and Aviation Environmental Research
SE-172 90 Stockholm, Sweden                     Fax : +46 (0)8-25 34 81
