Daniel Tourde wrote: > libpq-fe.h is there. I don't understand why it is not found then. The usual reason is because it isn't in one of the compiler's default include directories, and you haven't told configure to look for it anywhere else. -- Glynn Clements <glynn.clements at virgin.net>
