Thanks for your answer.
> > For the moment, when I want to display the map I have imported, I only
> > get a black window with some contours in white. I am expecting however
> > to see forests, roads, lakes, cities...
> > How can I achieve this result?
> The v.in.shape offers a "-l" flag to look at the table entries of the
> .dbf file. With "attribute", "label" parameters you can select
> the column of interest. No extra ARCView work is required.
Well, I am sorry but I am a newby. I am using the tcltk GUI and I am not
really familiar with the options offered by the different packages.
So, when I look in v.in.shape and find the parameters you are
mentionning, what do I do?
How can I import all the info? What will I get when I will export it as
an AutoCAD file?
		Daniel
Daniel TOURDE                             E-mail : daniel.tourde at foi.se
                                             Tel : +46 (0)8-55 50 43 44
                                        Cellular :  +46 (0)70-849 93 40
   FOI, Swedish Defence Research Agency; Aeronautics Division - FFA
       Dept. of Wind Energy and Aviation Environmental Research
SE-172 90 Stockholm, Sweden                     Fax : +46 (0)8-25 34 81
