[GRASSLIST:2446] Re: Grass5pre2. Compilation problem on RedHat 7.1
    Daniel Tourde
    ted at foi.se
    Tue Sep 18 07:28:41 EDT 2001
Hi!
> Sorry: unless you did not run "make install" (not possible for you in the
> moment), run
> bin.i686-pc-linux-gnu/gmake5
OK. I got this:
[root at brest src]#
/usr/src/redhat/BUILD/grass5.0.0pre2/bin.i686-pc-linux-gnu/gmake5
  SRC     = /usr/src/redhat/BUILD/grass5.0.0pre2/src
  CMD     = /usr/src/redhat/BUILD/grass5.0.0pre2/src/CMD
  UNUSED  = /usr/src/redhat/BUILD/grass5.0.0pre2/unused
  HEADER  = head.i686-pc-linux-gnu
  ARCH    = i686-pc-linux-gnu
  GISBASE = /usr/src/redhat/BUILD/grass5.0.0pre2/dist.i686-pc-linux-gnu
  VERSION = 5.0.0pre2 September 2001
Gmakefile not found (or not readable)
> The bug I have seen in your other mail tells me that "zlib.h" is not
> found. Please use the related configure parameter to tell GRASS where
> to find zlib.h.
OK. I will do it right now.
> > I will try to recompile with zlib but it seems that I need fftw.h and I
> > don't have this file (I have several ones that look like "cousin" of it
> > but not fftw.h)
> > [root at brest root]# locate fftw.h
> > /usr/include/dfftw.h
> > /usr/include/drfftw.h
> > /usr/include/sfftw.h
> > /usr/include/srfftw.h
> you should have:
> /usr/local/include/fftw.h
> (or that file in another place).
I downloaded fftw-2.1.3-8.src.rpm from Rawhide and I recompiled it by
myself. It is the last version available (I checked). I installed the
i386.rpm files and there is no fftw.h file
There are only the 4 files listed below (beside of the libraries by
themselves).
How did you install fftw? Is it the same fftw?
I did not have this problem (apparently) with grass5beta11.
> Sorry for all your problems, but up to know all will be resolved with
> specifying the path during the "configure" run.
I wonder about fftw.h but for the rest, I believe in it...
> You will finally manage, I am sure :-)
I am sure...
Thanks for your precious help
		Daniel
Daniel TOURDE                             E-mail : daniel.tourde at foi.se
                                             Tel : +46 (0)8-55 50 43 44
                                        Cellular :  +46 (0)70-849 93 40
   FOI, Swedish Defence Research Agency; Aeronautics Division - FFA
       Dept. of Wind Energy and Aviation Environmental Research
SE-172 90 Stockholm, Sweden                     Fax : +46 (0)8-25 34 81
