[GRASSLIST:2505] tcltkgrass--d.mon ERROR...
hsamanie at bio.puc.cl
Thu Sep 27 16:31:44 EDT 2001
Hi! I'm installing grass from the cvs fine...
GRASS GIS compilation log
Start of compilation: Thu Sep 20 15:43:26 MDT 2001
Errors:
End of compilation: Thu Sep 20 15:47:39 MDT 2001
DONE generating GRASS GIS binary code
although, whenever I try to start it get this error :
GRASS:~ > Error in startup script: unmatched open brace in list
while executing
"llength $line"
invoked from within
"if ![catch {open ~/.tcltkgrass r} stream] {
while {[gets $stream line] >= 0} {
if {[llength $line] != 2 || \
[set i [scan [lin..."
(file "/usr/local/grass5/tcltkgrass/main/gui.tcl" line 1842)
invoked from within
"source $env(TCLTKGRASSBASE)/main/gui.tcl"
(file "/usr/local/grass5/bin/tcltkgrass" line 17)
I looked for the file but couldn't fine the unmatched parethesis they
are refereing to... may be needing some extra pair
of glasses or is this something else?
Although everything seems to be in its correct place and work well until
I try to open a window...
and do:
GRASS:~ > d.mon x0
then I get this answer....:
Usage: x0 [-] "input_fifo output_fifo" [nlev]
Can't stat /usr/local/grass5/dev/fifo.1a
Problem selecting x0. Will try once more
I'm not very fluent programming and not a heavy grass user but really
want to be so that would help me to do thesis....
I'll appreciate any hint on this subject...
thanks,
Horacio
Horacio Samaniego
Museum of Southwestern Biology
Department of Biology
University of New Mexico
Albuquerque, NM. 87131
Phone (505) 277-5340 of.
(505) 301-3728
Fax (505) 277-0304 & 277-3838
(http://www.unm.edu/~horacio)
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20010927/6d0c8efb/attachment.html
