[GRASSLIST:3404] Re: database commands problem
Glynn Clements
glynn.clements at virgin.net
Mon Apr 1 18:35:15 EST 2002
adinno at hsph.harvard.edu wrote:
> newbie question. I try to use database commands (such as db.tables or
> db.select and I get the following message:
> DBMSCAP not set
> What up?
The DBMI library cannot find your dbmscap file; this file is described
in the db.connect manual page.
Glynn Clements <glynn.clements at virgin.net>
