[GRASSLIST:3417] Re: importing NRCS ssurgo data.
rgrmill at rt66.com rgrmill at rt66.com
Tue Apr 2 13:57:57 EST 2002
Michel Wurtz replied:
> Roger Miller wrote:
> > Folks,
> > I've been trying to import soil data (NRCS ssurgo data) into GRASS
5.0pre2.
> > I've found that v.in.arc will not read the *.e00 files at all.  iIt
reports
> a
> > fatal error reading the line file.  I does import the DLG files, but
once I
> use m.in.e00 for importing *.e00 files
Thanks Michel.  m.in.e00 did work.  I guess that means that the files
are not the problem and that v.in.e00 is broken.
The documentation for the ssurgo (SSURGO) data indicates that the DLG
data are the original data format and that the *.e00 data set may
contain errors.  As a result, I thought it would be a good idea to work
out a way to interpret the dlg data.  I used the data from the files I
imported with m.in.e00 to figure out how that should be done.  I'll
describe it here for the record.  There may be other ways to do it.
For each quadrangle (or 1/4 quadrangle in some cases) the ssurgo data
provide a line file and an attribute file.  In most cases there are also
special point feature files and attribute files for the point features.
I imported the vector objects from the line file using v.in.dlg.  I
Didn't use the "matt=" option.  The category number that v.in.dlg
associates with each area object is the minor code from the area record
of the dlg file.
The ssurgo attribute file consists of one record for each area object.
Each record contains four entries.  The first entry is the area object
ID (or a sequence number, I'm not positive which). The second two
entries are the last two values from each area record and I think these
are the major and minor codes.  The minor code is the same number used
in v.in.dlg as the category number.  The last entry on each line is the
map unit symbol.  It's possible to identify the mapped unit by querying
the imported file to get the minor code of an area then looking up the
code and map unit symbol in the ssurgo attribute file.  The map unit
symbol can be used to get entry to the many soil property tables in the
ssurgo data set.
It is also possible to build a GRASS dig_cats file from the ssurgo
attribute file.  I imported the ssurgo attribute file into a spreadsheet
program, deleted the first two columns, sorted the remaining columns
based on the minor code (first remaining column), deleted duplicate
records and exported the result as a tab-deliminated text file.  Using
an editor I converted each record in the tab-delimited file to the form
"minor code:map unit symbol" and copied the first 4 lines from an
existing dig_cats file to the top of the edited file.  I changed the
number of attributes listed in the first line of the header to match the
highest minor code in the file.  I then copied the edited file to
$LOCATION/dig_cats, gave it the same name as the file that contains the
vector data, and ran v.support on the vector file.
With a bit more spreadsheet or database work you can use the data in the
ssurgo data tables to build as many dig_cats files as you want, using
the map unit symbol to extract data from the ssurgo tables.
Roger Miller
Lee Wilson and Associates
