[GRASSLIST:3432] Re: v.geom?
Andrea Aime
aaime at comune.modena.it
Thu Apr 4 05:11:21 EST 2002
s.geom has been removed from GRASS due to incompatibility with the
GPL license. s.delaunay, s.voronoi and s.hull replace some of its
functionality (though s.voronoi and s.delaunay may produce wrong output
under very particular circumnstances, it's something you'll notice
immediately since the triangulation or the voronoi diagram are
clearly broken; anyway it's quite difficult to trigger the bug).
Hope this helps
Best regards
Andrea Aime
"J.c.m. van der Kwast" wrote:
> hi,
> I've just recompiled grass5.0pre3 and I'm unable to find the module
> v.geom. The only thing that I can find is the tcltk script voor the gui.
> Has anyone any clue as to where the module is to be found? I've looked
> in $path/src, $path/src.garden, $path/ src.contrib
> $path/dist.i686-pc-linux-gnu.
> Greetings sjors
