[GRASSLIST:3441] Re: Moving mapsets
Glynn Clements glynn.clements at virgin.net
Thu Apr 4 11:17:41 EST 2002
Gordon Keith wrote:
> Now I've become a bit more familiar with GRASS I've found I haven't set
> up my locations and mapsets in an optimal manner.
> What I'd like to do is move my various mapsets to all under the one
> location.
> Can I just move the directories using the unix mv command, or is there
> more to it than that?
> All mapsets are in the same projection (lat lon), but cover different
> regions. ie the PERMANENT/PROJ_INFO and PERMANENT/PROJ_UNITS are the
> same but PERMANENT/WIND isn't. As each mapset has its own WIND my guess
> is it's OK.
> On a related topic can I just rename the location and mapset
> directories to achieve a rename, or is that information hidden
> somewhere internally?
I don't know of any cases where the location name is stored in files.
However, there are a few cases where mapset names are stored:
1. The cellhd file of a reclass map stores the name and mapset of the
base map.
2. Setting the colour table of a raster map in a different mapset
stores the new colour table in
<current mapset>/colr2/<raster mapset>/<raster name>
There may be other cases. Try searching for mapset names in the files
(with find/grep).
Glynn Clements <glynn.clements at virgin.net>
