[GRASSLIST:3445] Re: Compiling r3.showdspf -- Summarized solution
Dietrich Lange
derdietrich at yahoo.de
Thu Apr 4 17:36:52 EST 2002
Hello,
thank you for your answers.
Because it was a little bit complicated to install the
r3* tools and regarding the compilation of
r3.showdspf.openGL i summarized all i done to
get the executables.
I did it as described in the previous articles and
with the help of
http://www.geog.uni-hannover.de/grass/grass5/README.mesa31
but some things don't work as described, so i
summarize now what i have done:
To obtain libMesaGLw.a and libMesaGLwM.a
I downloaded form http://www.mesa3d.org/
the file Mesalib-3.x.tar.gz
and compiled itlike ist das written in the
docs/INSTALL file:
./configure --prefix=/usr
make
make install
For the libaries libGLwM.a libGLwM.a and which seems
to be similar or equal to libMesaGLw.a libMesaGLwM.a
you have to go to the mesa directory: ./widgets-mesa,
and not to the directory
./widgets-sgi as desribed in the link above. There is
also an configure file,
which i didn't found in widgets-sgi. That's
the reason i stucked during comilation.
I compiled that directory with make instead of make
linux-elf as described in
the html document above:
as root:
make
and then as described:
cp -dpai libGLw.so* /usr/lib
and updated the linker:
/sbin/ldconfig
Then i canged to the main branch of the experimental
grass5 sources, which were
already compiled the normal way. There i changed the
file:
src.contrib/GMSL/g3d/src3d/raster/r3.showdspf.openGL/Gmakefile
as shown below, and not as described in
[GRASSLIST:1489]:Re: r3.showdspf,
because there they seem to work with the mesa
libaries:
original:
OGLLIB= $(OPENGLULIB) -lGL $(LGLWM) -lXm -lX11 -lXt
-lXext
changed to:
OGLLIB= $(OPENGLULIB) -lGL -lGLw -lMesaGLw
-lMesaGLwM ${LGLWM} -lXm -lX11 -lXt -lXext
then i changed back to the main-directory of grass and
did:
gmake5 -i src.contrib/GMSL/g3d
gmakelinks5 -i
and finally i could use the r3* commands and.
Thanks for your fast answer to my question yesterday.
Greetings
Carl Dietrich Lange
The following packages i used on an suse linux 7.3
computer with GL-graphics card:
xf86-4.1.0-45
xf86_glx-4.1.0-45
xf86glu-4.1.0-45
xf86glx-devel-4.1.0-63
xf86glu-devel-4.1.0-63
mesa-3.4.2-42
mesaglut-3.4.2-42
mesasoft-3.4.2-42
mesademos-3.4.2-57
mesa-devel-3.4.2-57
mesaglu-devel-3.4.2-57
mesaglut-devel-3.4.2-57
mesaglu-3.4.2-57
libtiff-3.5.5-195
lesstif-devel-0.92.32-47
lesstif-0.92.32-47
openmotif-devel-2.1.3
i think these are too much packages ,only have of the
rpm's is needed :)
__________________________________________________________________
Gesendet von Yahoo! Mail - http://mail.yahoo.de
Sie brauchen mehr Speicher für Ihre E-Mails? - http://premiummail.yahoo.de
