[GRASSLIST:3447] defining default region for importing data
Bill Rising brising at louisville.edu
Thu Apr 4 21:52:48 EST 2002
hello folks!
I've been tearing my hair out trying to do what should be the simplest
task: creating a new location.
I've found the information needed to get the projection commonly used for
the commonwealth of Kentucky:
(http://giac.state.ky.us/stateplane_parameters.htm)
Then... the dialog comes up for the default region, and I haven't a clue
what to specify. Where would I look to find this information?
I've already looked:
. through the Grass manual
. at various pages explaining how coordinate systems work, and how
projections are made
. through the Grasslist archives
I've already worked through all of the Grass Seeds tutorial, and though
it changes the local region for one map, it doesn't explain how it
decided on the numbers which get typed in. I've already gone through part
of the tutorial from the GRASS Anwender Verein, and the default location
has the big letters BEISPIEL (example) next to its numbers, without an
explanation.
I figure that they are some set of numbers in meters (as that is the base
unit for the projection I'm using), but that's about all I can figure out.
Is there a rule of thumb? Is there some place I can learn about how to do
this in general? Does it matter if the default region is misspecified?
Thanks in advance,
Bill
