[GRASSLIST:3493] Re: about writing a script program
marino vetuschi zuccolini
zucco at dipteris.unige.it
Thu Apr 11 04:28:34 EDT 2002
Hi to all,
I don't know if this is useful for you but i've some Grass command
nested in bash script procedure like that:
#!/bin/bash
$GRASS_ETC/run $GRASS_BIN/g.remove rast=MASK
$GRASS_ETC/run $GRASS_BIN/g.copy rast=mask_grid,MASK
$GRASS_ETC/run $GRASS_BIN/g.region n=${bound_4} s=${bound_3}
e=${bound_2} w=${bound_1} nsres=${nsres} ewres=${ewres}
where for my suite is
$GRASS_ETC=/usr/local/grass5/etc
$GRASS_BIN=$GRASS_ETC/bin/cmd
NOTE: for some grass programs like v.build.polylines you have to
recompile declaring exactly the path of v.support and v.in.ascii in
main.c
m.
>Hi,
> I used some commands in GRASS to analyse the data and got some
>resultant maps. Is it possible to write a script program including those
>commands I want to use, then execute the program to generate the resultant
>map automatically?
> Can I do that using Perl or I have to use some other scripting
>language? Where (web page) can I get some instruction?
> Thank you for your consideration and help.
>Fengxian Fan
>University of Hawaii at Manoa
Marino Vetuschi Zuccolini
DIPTERIS -Univ. Genova
Corso Europa 26, 16132
++ 39 010 3538136
http://ugo.dipteris.unige.it
