[GRASSLIST:3496] Re: about writing a script program
    Glynn Clements
    glynn.clements at virgin.net
    Thu Apr 11 04:54:36 EDT 2002
marino vetuschi zuccolini wrote:
> I don't know if this is useful for you but i've some Grass command
> nested in bash script procedure like that:
> #!/bin/bash
> $GRASS_ETC/run $GRASS_BIN/g.remove rast=MASK
> $GRASS_ETC/run $GRASS_BIN/g.copy rast=mask_grid,MASK
> $GRASS_ETC/run $GRASS_BIN/g.region n=${bound_4} s=${bound_3} e=${bound_2} w=${bound_1} nsres=${nsres} ewres=${ewres}
Notes:
1. You don't need to use etc/run for running normal commands.
2. The GRASS "bin" directory will be prepended to the path when you
start GRASS, so you don't need to specify it explicitly.
So, it would be sufficient to write:
g.remove rast=MASK
Glynn Clements <glynn.clements at virgin.net>
