[GRASSLIST:3499] Re: about writing a script program
Kevin Slover kjslover at nhc.noaa.gov
Thu Apr 11 10:36:36 EDT 2002
I have had some great luck with this actually using a shell script.  I
ran into a problem where I wanted to import 100+ ascii text files (xyz),
convert them to a raster, and then change resolution and colors...being
that my shell scripting has been limited to this point in time...it took
me a while.  However, it runs and does exactly what I want.  As long as
there are no complex calculations to make, shell might be the way to
go...I can give you an example of this script if you would like...
Fengxian Fan wrote:
> Hi,
>    I used some commands in GRASS to analyse the data and got some
> resultant maps. Is it possible to write a script program including those
> commands I want to use, then execute the program to generate the resultant
> map automatically?
>    Can I do that using Perl or I have to use some other scripting
> language?  Where (web page) can I get some instruction?
>    Thank you for your consideration and help.
> Fengxian Fan
> University of Hawaii at Manoa
LTJG Kevin Slover, NOAA
GIS Specialist/Meteorologist/Oceanographer
Tropical Prediction Center/Technical Support Branch
11691 SW 17th Street Miami FL 33165
(W) 305-229-4456  (F) 305-553-1264
