[GRASSLIST:3492] RE: about writing a script program
Byars, Bruce W. Bruce_Byars at baylor.edu
Thu Apr 11 03:21:17 EDT 2002
Look in the scripts directory in your installatoin.  There are some good
examples
in there you can modify/use.
Regards,
Bruce
	-----Original Message-----
	Sent: Thu 4/11/2002 1:13 AM
	To: GRASSLIST
	Cc:
	Subject: [GRASSLIST:3489] about writing a script program
	   I used some commands in GRASS to analyse the data and got
some
	resultant maps. Is it possible to write a script program
including those
	commands I want to use, then execute the program to generate the
resultant
	map automatically?
	   Can I do that using Perl or I have to use some other
scripting
	language?  Where (web page) can I get some instruction?
	   Thank you for your consideration and help.
	Fengxian Fan
	University of Hawaii at Manoa
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20020411/cc01571c/attachment.bin
