[GRASSLIST:3513] Re: shaded raster map
rgrmill at rt66.com rgrmill at rt66.com
Fri Apr 12 11:56:43 EDT 2002
> How can I make shaded raster map as a permanent map ?
Ahmet,
The raster map itself can be saved as an image file (tiff, png or ppm,
for instance) and printed using other software.  You can compose a more
complex illustration on the GRASS monitor, script the commands necessary
to recreate the illustration and then save it using the DCELL or PNG
drivers.  The raster file created that way can then be exported as an
image file and printed.
The most complete method for producing permanent maps from GRASS is to
use ps.map.  ps.map uses a series of commands (usually in a script file)
to produce postscript files from GRASS raster, vector and sites data.
ps.map can add text, icons, legends, scales and a few other extras.  The
postscript file can be printed or converted to other compatible
formats.
Roger Miller
