[GRASSLIST:3532] Re: NVIZ - visualization problem
Glynn Clements glynn.clements at virgin.net
Wed Apr 17 09:48:38 EDT 2002
marino vetuschi zuccolini wrote:
> the problem I found is in the realease .pre2 and .pre3.
> The situation is the most common in use of NVIZ: I load a DEM and a
> draping map.
> All runs ok if the model is 'totally' in between the NVIZ
> visualization window or without the principal NVIZ menu windows above
> it.
> IF I try to zoom the model and a border of the 3D model only touch or
> overpasses a window border, a vent of coloured bands start from a
> point in the lower left side of the window and the model is covered
> by this patches of colors. Obviously I cannot see anithing else.
> Any idea?
My guess would be a bug in your OpenGL implementation.
Glynn Clements <glynn.clements at virgin.net>
